12
This discussion topic has been answered Discussion topic: I’ve had fibre broadband installed and sky q box fine but my mini boxes won’t connect
This message was authored by: BrucieC
I've recently installed fibre broadband and my sky programmes work well on my main box however I cannot get my mini boxes to connect even following the advice on "fixing a problem". It seems that the mini boxes cannot now find the main unit
Avatar for BrucieC
Level 2 icon
This message was authored by: BrucieC Answer
Re: I’ve had fibre broadband installed and sky q box fine but my mini boxes won’t connect
Thanks for this response Old Fella but I hae tried all this before to no avail. I think this is something to do with fibre optics so am trying to sort through the broadband supplier.
Hi @BrucieC
Reboot the mini as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box
Avatar for BrucieC
Level 2 icon
This message was authored by: frudy1
@BrucieC BrucieC
 Hi did you ever get this problem solved and your mini box connected. I have the same problem and would love to know if there is a solution.
So you are doing a full network reset from scratch on the mini to get it to re-establish a link to the router? And from there it should find the Q again.
Chodley@
Thanks for your reply. I have tried what you say but still not connecting. To give a fuller picture of what is happening I switched broadband from Sky FTTC  to City Fiber FTTP. Sky Q box will not connect to the Sky mini box when using City Fiber FTTP (full fiber) ,everything else in the house connects perfectly, but when I switch back to Sky Broadband all is OK again.
I have spoken to Sky and after running through the usual "fixes" to solve a problem still no connection. So I am having a Sky engineer visit next Wednesday which hopefuly fix the problem.
Will keep you posted.
@frudy1 wrote:
Chodley@
@frudy1 you are aware that when Sky is not your broadband provider your main box oly connedcts to your 3rd part router on 2.4Ghz but more importantly the mini boxes only connect directly to your main box by way of a mesh created by the main box  and dont use your wifi. As you have an engineer coming out it may be that they willinstall a booster to help connect your mini to your main box
With Sky as your broadband provider then the rSky router forms part of the mesh so the mini box does use you home wifi
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Laing1,
Thanks for your reply and explanation. Would any Booster work or must it be a Sky model. I will no doubt find out when the engineer visits.
Will let you know the outcome.
@frudy1 wrote:
Laing1,
@frudy1 it need to be a Sky booster which if needed the engineer will fit free of charge
@BrucieC
 Problem solved
I had the router for newle connected FTTP running alongside the existing Sky FTTC both powered on. I disconected the Sky router and then ran through the installation process for the connection to th Qbox and then the Mini box. This time it connected immediately.
Perhapse a basic mistake on my part but could be useful information mation for someone in the same position as I was.
This message was authored by: Prabhu1
Not working
This message was authored by: Senga1
I'm having same issues with mini boxes since upgrading to fibre as everyone else in here so there is a major problem with fibre connection to mini boxes.
nothing to do with fibre. Just the fact the new sky routers no longer have the extra software in them which let them participate as peers in a Q mesh. So now the Q's wifi works just as badly as it always has with every other ISP and router.
see other wifi connection threads for various solution suggestions.
