Discussion topic: Having technical issues with Succession.
Message posted on 01 Apr 2024 12:04 PM
Been trying for an hour as it's been working fine most of the morning. Connections all seem good and other programs and apps are working.
Message posted on 01 Apr 2024 01:40 PM
Re: Having technical issues with Succession.
Is this on a Sky Q box ?
Message posted on 01 Apr 2024 01:55 PM
@caesarome yes, tried mary & George also and was having the same issue.
Should have really known to do this first, but after simply resetting my broadband and the sky q box, all is working fine again.
Thank you so much for the quick reply here too, as a new Sky customer, its amazing to know there's always support if needed.
Message posted on 01 Apr 2024 01:58 PM
I have moved this to the Sky Q forum for you.
