Discussion topic: Recording
This message was authored by: AlisonAshworth6
Recording
Hi
I cannot record anything on my sky Q box
Re: Recording
@AlisonAshworth6
What's happening when you try to record?
Avatar for AlisonAshworth6
Re: Recording
It says technicals error
Re: Recording
@AlisonAshworth6
Have you tried a reboot?
Once that’s back up and running do the same with any mini boxes if necessary-
~ press the 🏠 button
Re: Recording
I have tried that thank you
