3
This discussion topic has been answered Discussion topic: Hard drive issues
This message was authored by: HerrUther
Hard drive issues
I had an issue with my screen pixelating so I completed a reset. Now my Sky Q box says my hard drive has failed.
I've tried to access the hidden menu by highlighting setting pressing 001 and select. Nothing happens… the hidden menu stays hidden!
how can I reset my hard drive if I can't access the hidden menu?
This message was authored by: PandJ2020 Answer
Re: Hard drive issues
It's likely to be terminal: https://www.sky.com/help/articles/sky-q-hard-disk-error-messages
When you get a replacement box, remember to remove your viewing card...
Avatar for HerrUther
Yeah I managed to get into the hidden menu and do a hard drive reset and it still failed. Ordered a new box.
Let's hope it resolves the pixelation problem when it arrives 🤣😂
That might be dish alignment...
