Discussion topic: Glitchy tnt
This message was authored by: StevenWyatt82
Glitchy tnt
Trying to watch champions league on tnt and keeps glitching? Noticed that this problem has been going on for over a year now? How have bt and sky not resolved this issue?
Re: Glitchy tnt
I think TNT moved satellite frequencies a while ago and a slight dish misalignment could cause issues, but it would need an engineer out to check.
The simplest thing to try first is the usual troubleshooting though, check software is up to date, power the box off at the mains for at least 5 minutes etc.
If your broadband is fast enough you do have access to TNT Sports live through discovery+ which may be better for you while you wait for an engineer if that is the outcome.
sky Q 2 TB | sky Q Mini | sky Mobile | EE Full Works FTTC | LG B6 OLED | SONOS Beam 2
