This discussion topic has been answered Discussion topic: Fewer box set options on Sky Q?
Message posted on 26 May 2024 09:41 PM
Perhaps I'm doing something wrong - please tell me if I am - but if I didn't know any better, since upgrading to a Sky Q box around 10 days ago, I appear to have lost loads of available box set content options, despite my subscription remaining unchanged.
I used to be able to access an A-Z list of all available content for the different Sky channels that was often dozens of pages long. Now, the only A-Z I can find is under Sky Store, where a lot of content that I used to be able to access as standard it now says I have to pay for 'buy and keep'?
Has anyone noticed this? I'm starting to get the feeling I've been sneakily done over.....
Message posted on 26 May 2024 11:24 PM
@thenotrashcougar wrote:Thanks, I get search is the way to go most of the time but sometimes you don't know what you want to watch therefore a scroll through an organised A-Z sometimes helps.
I remain convinced I have lost content options under Box Sets. There is definitely less to choose from, a lot of it appears to be in Sky Store subject to extra charges.
Has anyone else found this to be the case?
Everything that's available as a Box Set on Sky HD is available on Sky Q, it's just not as easy to find as Sky Q's interface has always been a disorganised mess. Ideally you need to know what you're looking for as many programmes can only be found by searching for them by title.
Message posted on 26 May 2024 10:02 PM - last edited: 26 May 2024 10:04 PM
Re: Fewer box set options on Sky Q?
The amount of content on SKY Q is similar if not more than via SKY HD - what is different is how to find it.
I think it is more difficult to find things in generic way - lots is listed under either Catch up or On demand but not always quite where you think
A lot of content is easier to find using Voice search - but for that you need to know the titles or say things like 'Actor xxxxx" 'Western movies' , 'Romantic comedies'
there is a sort of A-Z under SKY Cinema (All) but it is pretty useless as it lists all without any a-z separation so takes ages to get to later movies
p.s. For some channels 'Catch up' is just that - the last couple of weeks with the rest being under 'On demand' but Channel 5 for example lists all on demand under the Catch up Section
Message posted on 26 May 2024 10:18 PM
Message posted on
26 May 2024
10:39 PM
- last edited:
27 May 2024
11:19 AM
by
Kelsingra
It's probably got a lot to do with the competitors- Disney, Apple, Paramount etc. There are a few programmes on Paramount that were on sky, but have now moved to the Paramount app!
Sky are quite sneeky too, I can't watch the F1 highlights that are shown on Channel4 when I try to watch it on my sky box, I have to watch it through the all4 app on my TV, with my skytv box turned off!
(removed)
Moderator note: Removed inappropriate language
