Discussion topic: what's the normal satellite signal strength?
This message was authored by: cintv
My satellite signal quality is 90 but the satellite signal strength is 70.  How much should be a norrmal, good signal?
Re: what's the normal satellite signal strength?
That's fine what you have @cintv
I've 90 Quality. 60 strength with no issues whatsoever
Avatar for cintv
Level 2 icon
Hi oldfella,
thanks for asnwering me so quickly 😀, do you know if there's an online sky guide about this technical details?
Nope
Do you have an actual problem with the signal?
Avatar for cintv
Level 2 icon
No problems now, there's a tree blocking the signal that I know so I keep it pruned,  I checked the signal and while the satellite quality increased to 90 the signal strength reached only 70 so I was wondering if it was fine
It is. Quality matters the most.
hi @cintv
One thing you may need to be aware of, for future reference,  is that the Signal Strength  guide on SKY Q does not show the strength/quality of the channel you are watching but a fixed transponder set in an engineers menu.
Thus it may show a good quality when some channels on a different/weaker transponder may have issues
Avatar for cintv
Level 2 icon
Thanks, for now I use it to check if the signal is coming back after pruning the tree, and the channels have all a good signal
