Discussion topic: Apps not working
This message was authored by: Dippedsoda
Apps not working
BBC Iplayer not working, Paramount+ not working on Sky?
Re: Apps not working
@Dippedsoda you could try refreshing the apps in the engineers menu
To enter the engineers menu do the follow
press the home button then scroll down to setting and hi-light
do not press select/enter but press 001 then select this takes you into the engineers menu
scroll down to apps > refresh
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
