Discussion topic: Fast forward not working properly
Message posted on 16 Apr 2024 05:54 PM
Re: Fast forward not working properly
Hi, we went through the annoying trouble shooting on the phone with Sky (lost all our recordings, as had to do a reset) and then as expected they said we'd have to have an engineer. Booked one and he replaced our box and all is now okay. Our box was 6 years old though, a newer one shouldn't have this problems, unless they gave you a refurb. I'd persist with them on the phone, annoying though it is, and get an engineer out as you don't own the box so you shouldnt have to suffer with a fault.
Message posted on 16 Apr 2024 08:32 PM
Sky have been no help at all with the problems that we've had( we've had quite a few problems. It sounds as if there is a problem with the box, but they keep asking me to try different things,which make no difference at all, and they cannot understand what is going on
Message posted on 11 Feb 2025 08:02 AM
Probably a bit late now, but I had this problem. I sorted it by permanently deleting the items you have already deleted. To do this, from recordings go down to manage, press right, go down to deleted. You then get a list of all the programs deleted. Go through each one and permanently delete.
