8
This discussion topic has been answered Discussion topic: Failed. Location check failed
This message was authored by: Jamie185
Hi there
For nearly 2 weeks now, we are unable to download on demand programs or films and we get the above error message. Have spoken to my isp and they've confirmed all is good their end and my IP address definitely shows as the UK. We're also unable to use our sky go app on ps4 which we presume is connected. Can someone help please?
Re: Failed. Location check failed
@Jamie185 wrote:
Hi there
Hi @Jamie185
Have you tried completly resetting your Q box connection/
@Jamie185 wrote:
Hi there
Hi @Jamie185
Avatar for Jamie185
Hi there
Yes I did this with community fibre yesterday but no joy.
Avatar for Jamie185
I've seen another chat which says sky have stopped recognising the IP address and they need to add it to their database. At the end of the day, I'm not getting a service I pay for so will be complaining to sky as it will be their problem when I have to cancel my package. Sigh.....
Hi @Jamie185   So what does a IP Location Checker show https://www.iplocation.net
It's not really Sky's problem though. I've had the same at work for broadband and mobile issues and it's caused by suppliers buying block IP addresses and telephone numbers which aren't whitelisted by anyone else.
Obviously if you're in contract for TV with Sky then this certainly isn't a valid reason for asking to leave penalty free.
Avatar for Jamie185
Hi @MightyQuinn
this is what I get
Avatar for Jamie185
Will see what sky say and then go back to ISP
