Discussion topic: Ethernet mini box issues
This message was authored by richardwyatt This message was authored by: richardwyatt
I know this has probably been covered a load of times with varying degrees of issues. I can't quite find an answer so far that works.
we have sky q and 1 mini box in another room. They are only connected through Ethernet using power line connectors. The mini box is just a joke at watching anything live. I was trying to watch the football and it constantly drops out and the picture freezing. You get 5 seconds and then 2 seconds of freezing. It's utterly infuriating. I've resorted to recording live tv and then watching the recording a few seconds behind. This never has any issues. So this means;
a. There is no issue with the network connection as the streaming of just a few seconds delay works fine
b. The mini box is fine as it can play recorded things just fine!
why is this so hard to work normally watching live tv?? This is so frustrating and seemingly a software issue more than the way the network is operating.
any ideas??
Re: Ethernet mini box issues
any ideas??
Hi @richardwyatt
Unfortunately Powerline is never guaranteed and depends heavily on the complexity and condition of your mains wiring.
What Powerline units are you using and how exactly are they connected and where are they located?
richardwyatt
Our house got rewired 10 years ago and we've never had any issues with them other than with this mini box. If we can steam recorded tv but not live tv then surely the network isn't the issue?
we use TP Link power line adapters and have 1 right at the router and the send next to the mini unit.
The wifi with boxes was seperated by a wall and it never worked. Was atrocious and the engineer said that a wall is enough to block the signal!
Who is your Broadband supplier @richardwyatt
