Discussion topic: My mini box will not connect with sky q. I have rebooted all systems. Having Q was a big mistake
Message posted on 26 Jun 2024 09:44 PM
Message posted on 26 Jun 2024 09:55 PM
Re: My mini box will not connect with sky q. I have rebooted all systems. Having Q was a big mistake
Reboot the mini as above.
