Discussion topic: Error mr104 at night.
Message posted on 07 Oct 2023 03:49 AM
I only every get this error at night (mini box), I have tried resetting both boxes and turned off eco mode, but it happens every night.
Message posted on 07 Oct 2023 05:59 AM
Re: Error mr104 at night.
mr 104 is an issue with the mini box connectivity to your main Sky Q box. Give Sky a call and discuss having them supply a Sky Q booster which needs to be located about half way between your main and mini box. Sky should supply these free of charge if I remember correctly.
Message posted on 07 Oct 2023 06:48 AM
This can also happen if your main Sky Q box has eco mode enabled as this fully shuts down the box.
Message posted on 12 May 2024 10:31 PM
I have exactly this problem too. It's only started happening in the past 3 months or so. No network or internet changes and the main box and mini box are only about 10 metres apart. Happens either at about 10.20 or 11.20 pm. Anyone got any ideas?
Message posted on 22 Sep 2024 07:42 AM
I've only started having this issue since switching my Broadband supplier from BT to Sky, has the booster resolved for others?
Message posted on 18 Oct 2024 02:09 PM
My Sky Q shuts down at some stage after midnight and comes back on line at 7 am. I read that if ECO mode is enabled the Sky Q Box will shut down. Does anyone know how to disable the ECO Mode?
Message posted on 18 Oct 2024 02:15 PM - last edited: 18 Oct 2024 02:16 PM
It normally resets before 6am so may not be relevant but see this link
https://www.sky.com/help/articles/using-the-standby-settings
Message posted on 18 Oct 2024 02:18 PM
@Edgecombe1 wrote:My Sky Q shuts down at some stage after midnight and comes back on line at 7 am. I read that if ECO mode is enabled the Sky Q Box will shut down. Does anyone know how to disable the ECO Mode?
Eco Mode only operates from 02:45-05:45 so if you're having problems at midnight or 7am, that will not be related.
Message posted on 21 May 2026 10:12 PM
Same problem, almost every single night anytime after 4pm but mainly from 10:30-11pm like clockwork the mini box cuts out and or shows the MR104 when turned on.
Literally every single night yet wake up in the morning and it works perfect.
All eco modes turned off, have a booster tried all the resets hundreds of times!
At my wits end with it now ready to cancel the lot and give up!
Message posted on 21 May 2026 10:15 PM
Did u ever find a solution? I have exactly the same been like it for months now ready to give up
