Discussion topic: SKY Q - Technical Fault with this Channel
Message posted on 21 May 2026 02:17 PM
Hi all
Over the last week or so, my SkyQ box has a blue screen that states "There is a Technical fault with this channel. Please try again later"
I have unplugged / updated software etc and still having the same issue. Even the mini box in my other room has the same issue.
Can anyone please advise what I can do to resolve this?
Many thanks
B
Message posted on 21 May 2026 02:19 PM
Re: SKY Q - Technical Fault with this Channel
Try the troubleshooting on this link.
https://www.sky.com/help/articles/there-is-a-technical-fault-with-this-channel
Message posted on 21 May 2026 04:13 PM
Thank you. I will check the link and hopefully find a solution. I feel an engineer might be my next step unfortuntely.
