2
This discussion topic has been answered Discussion topic: Damage due to poor installation
This message was authored by: alistair1951
Been with Sky for almost 30 years. Upgraded to Sky Q earlier this year which involved a change of dish as the old one was badly corroded. The installer re used the existing cabling.
Last nights storm brought a lot of heavy rain. This morning the Sky Q box wasn't working. I reset it and it worked for a while then stopped. I decided to pull the power cord and in doing so discovered a large puddle of water on the glass shelf under the box. Traced it to water dripping out of one of the two cables to the dish. Dried it up, reset the box and it worked ok.
Contacted Sky who said they would send an engineer to check the cabling but Friday before this can happen.
Later this afternoon the box stopped receiving a signal again, a technical issue.
The cable that appears to be causing the problem is very old, the original single LNB cable prior to a second cable added for HD. When the dish was renewed I thought the cabling looked very loose and sloppy hanging from the LNB on the chimney but it worked.
Do you think my existing box is screwed?
This message was authored by: Laing1 Answer
Re: Damage due to poor installation
@alistair1951 the engineer can check the box when they come to look at the cabling if it needs replacing then they will replace it free of charge as Sky own all the Q boxes
Avatar for alistair1951
Engineer came today, couldn't believe the state of the last install. Replaced cabling from dish with new twin cable and had to replace box due to water damage. At least it's properly done now.
Answered - Go to Answer
