7
This discussion topic has been answered Discussion topic: My Sky Mini Box does not respond to the remote control.
This message was authored by: IanD57
My Sky Mini Box does not connect with the main Sky Q router and does not appear to respond to the remote control. I have changed batteries in the remote and still does not work.
Avatar for IanD57
This message was authored by: IanD57 Answer
Re: My Sky Mini Box does not respond to the remote control.
Thanks oldfella - reset the remote as you suggested and was then able to follow onscreen instructions and get the mini box reconnected.
Hi @IanD57
Try completly resetting your mini Bluetooth remote.
Then make sure that you are pointing your remote at the mini box and press 1 & 3 together until the remote led flashes and follow onscreen instructions to re- pair.
Avatar for IanD57
This message was authored by: Barney12
I'm having the same problem. My remote is now not connected to my sky mini box. Any suggestions I've tried the seven and nine and the one and three that doesn't make any difference any other suggestions please?
This message was authored by: Shandon
I'm having this same problem as well. Multiroom box is not responding to any of the remote controls. Remotes working ok with the TV so seems to be a box problem
@Shandon Have you tried rebooting your main mini box ie
then
Try resetting your remote.
Press the buttons 7 & 9 together on the remote until it’s led flashes four times.
Then press 1 & 3 together until the led flashes twice then follow onscreen instructions to repair the remote.
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
This message was authored by: Rebecca2221
I have beem trying this on repeat. I have a sky mini box and have bought a sky Q remote online.
I have followed the instructions exactly, but no instructions appear on screen at the end
This message was authored by: Victor19
My main sky box is not responding secondary box upstairs is fine
replaced batteries in remote  and unplugged box as required still no joy
