2
This discussion topic has been answered Discussion topic: Dace
This message was authored by: Dacey1
Dace
You can't watch TV at the moment as there is a connectivity problem..
however settings show connection to sky Q box and the Network.
the other TV says it's a technical problem- any help?
This message was authored by: Laing1 Answer
Re: Dace
@Dacey1 Have you tried rebooting your main Q box ie
then reboot
the other box
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Re: Dace
then reboot
the other box
Avatar for Dacey1
Re: Dace
Yes thanks that sorted it 👍
