Discussion topic: Mini hub and remote not working
This message was authored by: Kayforbes
My mini hub and remote control are not working. Main tv ok. Can't access settings. To just playing random Spotify advert
Re: Mini hub and remote not working
@Kayforbes Try resetting your remote.
Press the buttons 7 & 9 together on the remote until it’s led flashes four times.
Then press 1 & 3 together until the led flashes twice then follow onscreen instructions to repair the remote.
if that doesnt work try rebooting your mini box ie turning off at the wall for 30 seconds then turning it back on
then
reset your remote
