7
This discussion topic has been answered Discussion topic: Checking upgrade box on Screen
This message was authored by: Christine+U
Checking upgrade box on tv screen wont move, cant watch tv?
This message was authored by: GD1 Answer
Re: Checking upgrade box on Screen
@Christine+U  It's possible this is the message from your actual TV & not the Sky Q box, you may need to use the TV remote to remove the message.
Hi @Christine+U
Try rebooting your Q box
Avatar for Christine+U
Thanks, i will try that
Not worked. It says keep power on til upgraded?
Yes it was, thanks
This message was authored by: tracey264
I have the same, will not go off at all
hi @tracey264
As above this is likely to be your TV's firmware and you will need to use the TV;s own remote to proceed
