Discussion topic: Live TV Flickering
Message posted on 19 Mar 2025 09:50 PM
Live TV Flickering
I have a problem with my Sky. I am getting Live TV flickering and going to black randomly and it affects all channels. Playback of recordings do not flicker and watching streaming content via the Sky Q does not flicker.
Sometimes powering off and back on the box clears the issue, so maybe it's an intermittent software fault?
Does anyone have any ideas on how to permanently fix it as I am tired of having to reset the box?
Is there an software update?
Thanks in advance
Message posted on 19 Mar 2025 09:54 PM
Re: Live TV Flickering
Thanks in advance
Hi @rayraff
Message posted on 19 Mar 2025 10:06 PM
Ok, I do that and now I've lost all the apps Netflix, Disney+, etc
How do I get them back?
Message posted on 20 Mar 2025 04:29 PM
Did the reset and then updated to latest software and now it's bad again with the picture and sound breaking up but only on Live TV. Recordings are working fine with no picture or sound break up. Streaming content is working fine with no picture or sound break up. Based on this I believe the dish and cables to the Sky box and from the Sky box to the TV are all okay.
Is Sky working on a new version of software to fix this issue?
Is it a known issue with rhe current version of software?
Message posted on 20 Mar 2025 06:18 PM
No current issue with Software @rayraff
Updating Software is only necessary if the Q box is not on the latest version.
Message "update this box with latest version " is always shown even when the Q box is on the latest.
Uodating when on the latest does not refresh the software.
You say issue is only with live TV.
Have you tried recording content now which is currently live ? And the checking the playback?
Message posted on 20 Mar 2025 06:22 PM
If I reset the settings it loses apps like iPlayer, Disney, Netflix, Prime, etc and I want those.
The Sky Q box is about 7 yrs old.
I will try recording some live TV and seeing if the recording is ok. It does seem to affect ITV and Channel 4 most.
Message posted on 20 Mar 2025 07:34 PM
Live TV programme broke up and screen went black for a second or two. Recorded version of Live TV programme made at the same time as we watched the Live TV did not break up or have the screen go black.
Message posted on 20 Mar 2025 07:36 PM
Hi @rayraff
If you lose the Apps you just need to refresh them in the Hidden menu.
Select Apps
then highlight Refresh all Apps on this box.
You'll see a message that says, 'Your apps are being refreshed'. This will stay on screen until you press Dismiss to return to normal viewing
It’s recommended waiting at least 5 minutes before doing so.
Refresh Apps can take up to 24 hrs to complete .
Message posted on 20 Mar 2025 07:39 PM
If I reset settings it takes the box back to software as it was back in 2018 when we got the box. To get the streaming apps back I had to update software to latest version.
Message posted on 20 Mar 2025 07:42 PM
Message posted on 20 Mar 2025 07:46 PM
I will try doing it again and double checking I didn't have finger trouble.
Thank you!
Message posted on 20 Mar 2025 07:59 PM
Message posted on 20 Mar 2025 08:02 PM
Currently on Q280.000.08.00L (5vosfts)
Message posted on 20 Mar 2025 09:48 PM
I did Reset Settings and once again it lost all the apps except the Sky app.
Message posted on 20 Mar 2025 09:57 PM
Hi @rayraff
Have you tried rebooting your Q box?
If you still have no Apps try refreshing the Apps in the Hidden menu.
Select Apps
