Discussion topic: Paramount+ not in region
This message was authored by: MikeYiannis
Paramount+ suddenly not working. Last night was a code 3304 (licence not supported in region) and now states were in the US, we're in England! I have followed all suggestions (reboot box, reboot WiFi, refreshed apps, updated software) but nothing. Works fine on paramount app on phone so has to be sky q?
Re: Paramount+ not in region
You sure it's using the same id on both devices?
Avatar for MikeYiannis
Thanks, yes same ID
This message was authored by: AndrewF_UK
What ISP are you with @MikeYiannis?
Consider liking this post if it was helpful, or mark as an answer if it solved it for you.
Sky Stream customer. Past user of Sky Digital, Sky+, Sky+ HD and Sky Q. 3x pucks. Main TV is an LG OLED with Sonos Beam.
Starlink
The phone is also using starlink at the same time? And not 4G/5G?
This message was authored by: Gazab
Same here any help would be greatly appreciated also on starlink
Only Paramount+ can fix their stupid geoblocking. Starlink sometimes goes through a US hub.
It's only just started **bleep** ... have you got yours sorted
It's only just started ... have you got yours sorted
Yeah it will be random because sometimes (usually?) it will use a UK hub/pop
I guess the question was to @MikeYiannis
Hi, I reset the Starlink and it seemed to do the job, but every now and then paramount kicks us out so we have to log back in, rest router and it fixes it. Only have this problem with paramount on sky!
