Discussion topic: Changing Wifi Network - Mini Box not connecting
This message was authored by: NickF8
HI
I hope someone can help… I have a Sky Q Main box, a Sky Q Wireless Extender and a Sky Q Mini Box. I am trying to change the Wireless network it uses as I am moving away from Sky due to slow speeds and they don’t have fibre in my area.
I successfully did the Reset on the Main Q box and connected it to the new Wireless network1, so all good there. I did the WPS button on the Q Extender and on the Main Q box, as I think this is how you sync those up ? Then did it with the Mini Q upstairs – However, after restarting all 3 boxes, the Mini Q says it can’t find the Main Q box.
What am I doing wrong ? Does anyone know the correct process please ?
This message was authored by: Addie15
Re: Changing Wifi Network - Mini Box not connecting
This message was authored by: Lisa-P1987
Update - spoken to @NickF8 and after some steps the issue is resolved.
Lisa - Sky Tech Team Expert
This message was authored by: Tom871
Hello I have the same problem. Please advise
This message was authored by: SerFinchalot.TTV
Hello, I also have the same issue.
please advise what steps were taken to resolve OP's issue.
doesnt allow me to simply search for a new WiFi, wants me to enter an IP address manually (which doesn't work)
This message was authored by: Claire00zz1
Can you please advise how to do this as I have the same issue. @Lisa-P1987
@Lisa-P1987 wrote:
Update - spoken to @NickF8and after some steps the issue is resolved.
Can you share what was done.?
Have you done a network reset preocess on the mini?
This message was authored by: NicTay215
I also have this issue?? How did you resolve it please?
Avatar for NickF8
Hi
My issue was I had 3 x SSIDs on the same Wifi Router and initially did not use the first (main) one for the Sky Devices. When I changed to using thst one, they all connected up using the Standard sequence of Main Q Box, Extender, then Mini box.
This message was authored by: Mr+Flibbles+86
Thanks for escalating this. We’ve sent an invite to @NicTay215 to chat.
Could I have some assistance as well please?
We are still looking to help you @NicTay215. If you need our support let us know and we can re-escalate to our chat team. Your invite has been closed now. Thanks
Can I have assistance with the same issue please??
