Discussion topic: Change BBC1 region
This message was authored by: OldJohn99
Change BBC1 region
I've just moved. Default BBC1 is still my previous area. How do I change to this area?
Re: Change BBC1 region
Did you tell Sky you've moved?
@OldJohn99  Have you updated your address on your sky account as the default is set by your registered postcode
Avatar for OldJohn99
Yes - and they fixed a new dish here
Yes - a few days ago
This message was authored by: ozsat
It will change automatically based on your postcode - but does seem to take a while to filter down to the card.
SkyQ Silver bundle (V2 2TB with UHD/HDR + two minis) in Sky region #71 (Oxford) using VirginMedia Gig1 Fibre (1.2Gbps/100Mbps).
Many thanks
This message was authored by: Invisiblename
@OldJohn99 wrote:
Many thanks
In the meantime you could always navigate to the 950s where the other BBC channels are and save yours to your favourites
I am just another Sky customer!
