Discussion topic: Change BBC1 region
Message posted on 13 Jun 2025 03:26 PM
Change BBC1 region
I've just moved. Default BBC1 is still my previous area. How do I change to this area?
Message posted on 13 Jun 2025 03:29 PM
Re: Change BBC1 region
@OldJohn99 wrote:I've just moved. Default BBC1 is still my previous area. How do I change to this area?
Did you tell Sky you've moved?
@OldJohn99 Have you updated your address on your sky account as the default is set by your registered postcode
Message posted on 13 Jun 2025 04:02 PM
Yes - and they fixed a new dish here
Message posted on 13 Jun 2025 04:05 PM
Yes - a few days ago
Message posted on 13 Jun 2025 04:58 PM
It will change automatically based on your postcode - but does seem to take a while to filter down to the card.
SkyQ Silver bundle (V2 2TB with UHD/HDR + two minis) in Sky region #71 (Oxford) using VirginMedia Gig1 Fibre (1.2Gbps/100Mbps).
Message posted on 13 Jun 2025 05:02 PM
Many thanks
Message posted on 13 Jun 2025 07:37 PM
@OldJohn99 wrote:Many thanks
In the meantime you could always navigate to the 950s where the other BBC channels are and save yours to your favourites
