Discussion topic: Bush smart tv
This message was authored by: Sally34
Bush smart tv
Cant connect my sky q remote to tyrn tv on off
Re: Bush smart tv
@Sally34 Try resetting your remote.
Press the buttons 7 & 9 together on the remote until it’s led flashes four times.
Then press 1 & 3 together until the led flashes twice then follow onscreen instructions to repair the remote.
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
This message was authored by: TBT1
Re: Bush smart tv
I am not able to pair my Sky Q remote with Bush TV. Have done buttons 7 and 9 together and then 1 and 3. Step holdinh 1 and 3 together always fail. Any advice please?
Re: Bush smart tv
@TBT1 is your Q box switched on ? what messages are you seeing on the screen when you press 1 and 3 together also are you pointing the remote towards the sky box
Re: Bush smart tv
Sky Q box on. Remote pointed to box. Error: try again...
Re: Bush smart tv
@TBT1 ok Have you tried rebooting your main Q box ie
