Discussion topic: Broadband connectivity
Message posted on 21 Dec 2023 12:24 PM
Hi, recently changed from Sky broadband to an infinitely faster Virgin fibre broadband. Every other device in the house works perfectly well but I have an issue with my Sky Q box. Every day (must be on power down it loses connection with the broadband, and forgets the password so I have to re-enter a 16 digit password every day. There must be an easy way of fixing this. Sky helpline asked me to upgrade Sky Q and seemed confident this would solve the problem, but it didn't. Any ideas please ?
Message posted on 21 Dec 2023 02:18 PM
Re: Broadband connectivity
You may want to change your standby settings:
Press Home on your Sky Q remote select Settings > Setup > Preferences > Standby mode, and select the setting you want. I have all my boxes set to NONE. I had the same issue as you at the beginning of my SKY Q days and this sorted it out as soon as I'd set all boxes to the same.
Good luck.
Samsung UE49MU7070XX - Samsung MS550 Soundbar+ with 9000S Rears
Sky Q 2Tb + 3 Minis - BT Full Fibre 900
Message posted on 22 Dec 2023 07:20 AM
Thanks, I'll try that. Will take a couple of days before I know it's worked so I'll report back after the weekend, have a good Xmas everyone.
Message posted on 03 Jan 2024 09:09 PM
Hi, my broadband signal keeps dropping out on SkyQ. My box informs me i have no broadband signal, but when I look at all my other devices (phones, laptop, ipad) the broadband signal is there, and very strong (over 200Mbps with Virgin fibre)
The signal drops out for hours on end, then, next morning it's reconnected itself. I fear that if I call Sky I will find myself in the middle, between Sky and Virgin, both blaming each other. Anyone else had experience of this ?
