This discussion topic has been answered Discussion topic: BBC Sounds
Message posted on 06 Sep 2025 08:11 PM
Re: BBC Sounds
@CMC6 wrote:The BBC sounds app works ok through our LG tv. Very difficult to know who it is that can fix this!
I suspect this is a BBC issue and even if it is a Sky Q problem, you have to get the BBC to say it isn't their app at fault or at least, say they can't replicate the problem before Sky will take a look.
Why?
Because most of the time the app is at fault. We blamed Sky for all the issues on Q with YouTube that took months to resolve, but it was the app.
That all said, the Q box hardware is getting a bit long in the tooth now and most people will have a better app experience using the ones on their smart TV or streaming device if they have one.
In the meantime, BBC radio stations (and others) are still being broadcast on Q from channel 0101 onwards.
sky Q | sky Mobile | EE Full Works FTTC | LG B6 OLED | SONOS Beam 2
Message posted on 09 Sep 2025 06:02 PM
Re: BBC Sounds
Seems to be fixed now. Can listen to BBC Sounds live now.
Message posted on 09 Sep 2025 06:13 PM
Re: BBC Sounds
Thanks for telling me, I have sound back too - BBC still haven't replied to my emails, probably too busy with scandals!
Message posted on 09 Sep 2025 06:54 PM
Re: BBC Sounds
@bigal43 wrote:Thanks for telling me, I have sound back too - BBC still haven't replied to my emails, probably too busy with scandals!
No response here either.
Message posted on 09 Sep 2025 08:42 PM
Re: BBC Sounds
Yes, it's back working for me. No response from bbc sounds about the issue. Thanks to everyone for their help and suggestions
Message posted on 11 Sep 2025 01:48 PM - last edited: 11 Sep 2025 01:49 PM
Re: BBC Sounds
Message received today from BBC Sounds confirming the fix had been deployed. Not sure it went through a spellchecker first, but at least they replied 👍🏻
BBC Sounds response
Message posted on 11 Sep 2025 02:47 PM
Re: BBC Sounds
Hi,
I've just had the same reply sent to my email, better late than never, I really apprfeciate (sic) everyone helping me with this issue.😀
Message posted on 11 Sep 2025 06:06 PM
Re: BBC Sounds
Yes it was very helpful, this Sky forum. Couldn't seem to get anywhere with an independent search for an answer.
Message posted on 11 Sep 2025 06:15 PM
Re: BBC Sounds
hear hear!
Message posted on 11 Sep 2025 06:31 PM
Re: BBC Sounds
I also had a reply from BBC Sounds, but they totally misunderstood the issue and told me it was probably being caused if I was using a VPN on my tv! Thank goodness for the sky community
