24
This discussion topic has been answered Discussion topic: BBC Sounds
This message was authored by: bigal43
BBC Sounds
bbc sounds app on sky tv has lost audio - everything else is ok
This message was authored by: stereohaven Answer
Re: BBC Sounds
Not an app I ever use, but I have tested and get the same result, everything works apart from live audio.
I would recommend everyone starts raising this with the BBC directly: https://www.bbc.co.uk/sounds/help/questions/need-more-help/report-fault
I can flag this thread to Sky Community staff, but most of the time, these things end up being an app bug that the provider needs to fix.
sky Q 2 TB | sky Q Mini | sky Mobile | EE Full Works FTTC | LG B6 OLED | SONOS Beam 2
Re: BBC Sounds
@bigal43
Is this on Sky Q, Glass or Stream as it isn't Sky Go related (where you had posted).
Avatar for bigal43
Level 2 icon
Re: BBC Sounds
this on sky q, sorry I am new to this
Re: BBC Sounds
No probs, I have moved this to the Sky Q board for you.
Avatar for bigal43
Level 2 icon
Re: BBC Sounds
Thanks for that
This message was authored by: DavidMHar
Re: BBC Sounds
I have the same lack of audio issue, but only on live radio. Does anyone know how to fix it?
This message was authored by: CMC6
Re: BBC Sounds
BBC Sounds not playing live radio on any station. I've tried resetting the sky box, reconnecting the router, refreshing apps, but nothing seems to make any difference. First world problem I know, but irritating.
Re: BBC Sounds
Avatar for bigal43
Level 2 icon
Re: BBC Sounds
Thanks for this, I appreciate you taking the trouble, at least I know now that it's the BBC, I have already raised a case with them & I had one reply asking me for more information - what version of Sounds I have and the System Information of the device. I supplied all this info to them on 3/09 but have not had a reply as yet
Re: BBC Sounds
I also raised it and sent a link to this thread.
Avatar for bigal43
Level 2 icon
Re: BBC Sounds
Thanks - watch this space I guess, i can listen on radio but sound quality not as good!
Re: BBC Sounds
It must be a Sky Q issue.
I have  just tried on my TV, Roku and also both my Sky Stream pucks and managed to play Radio 1 to 5 without issue.
It is not an app I use on a regular basis, as do not ever listen to BBC radio.
Would also suggest sending an email to the Sky Viewer relations team to report it;
[email protected]
They will pass on such device problems to a third party, in this case the BBC.
They do respond to emails with any updates for your queries or problems.
Avatar for bigal43
Level 2 icon
Re: BBC Sounds
Thanks, I will try that but I don't think its a Sky problem  as all other apps work perfectly.
Re: BBC Sounds
The BBC sounds app works ok through our LG tv. Very difficult to know who it is that can fix this!
Re: BBC Sounds
Thanks for the link.
