24
This discussion topic has been answered Discussion topic: BBC Sounds
Re: BBC Sounds
@CMC6 wrote:
The BBC sounds app works ok through our LG tv. Very difficult to know who it is that can fix this!
I suspect this is a BBC issue and even if it is a Sky Q problem, you have to get the BBC to say it isn't their app at fault or at least, say they can't replicate the problem before Sky will take a look.
Why?
Because most of the time the app is at fault. We blamed Sky for all the issues on Q with YouTube that took months to resolve, but it was the app.
That all said, the Q box hardware is getting a bit long in the tooth now and most people will have a better app experience using the ones on their smart TV or streaming device if they have one.
In the meantime, BBC radio stations (and others) are still being broadcast on Q from channel 0101 onwards.
LG B6 OLED 55” | LG UP75 LCD 43” | sky Q | sky Q Mini | SONOS Beam 2 | Apple TV 4K | EE Full Works FTTC
This message was authored by: CMC6
Re: BBC Sounds
Seems to be fixed now. Can listen to BBC Sounds live now.
Avatar for bigal43
Level 2 icon
This message was authored by: bigal43
Re: BBC Sounds
Thanks for telling me, I have sound back too - BBC still haven't replied to my emails, probably too busy with scandals!
Re: BBC Sounds
No response here either.
This message was authored by: DavidMHar
Re: BBC Sounds
Yes, it's back working for me. No response from bbc sounds about the issue.  Thanks to everyone for their help and suggestions
Re: BBC Sounds
Message received today from BBC Sounds confirming the fix had been deployed. Not sure it went through a spellchecker first, but at least they replied 👍🏻
BBC Sounds responseBBC Sounds response
Avatar for bigal43
Level 2 icon
Re: BBC Sounds
Hi,
I've just had the same reply sent to my email, better late than never, I really apprfeciate (sic) everyone helping me with this issue.😀
Re: BBC Sounds
Yes it was very helpful, this Sky forum. Couldn't seem to get anywhere with an independent search for an answer.
Avatar for bigal43
Level 2 icon
Re: BBC Sounds
hear hear!
Re: BBC Sounds
I also had a reply from BBC Sounds, but they totally misunderstood the issue and told me it was probably being caused if I was using a VPN on my tv! Thank goodness for the sky community
Answered - Go to Answer
