Discussion topic: Aerial
This message was authored by GeorgeWatt This message was authored by: GeorgeWatt
Aerial
Similar to Brian I am trying to reduce wires around my living room - so if I get a new smart TV - other than connecting the HDMI to the Sky Q Box and Tv - what other connections do I need other than Power ? How is the Sky dish connected to the TV then or the Sky Q Box ? Do i need an aerial connection ?
This message was authored by PandJ2020 This message was authored by: PandJ2020
Re: Aerial
Satellite feeds have to be connected to the main Q box via cable - there is no alternative (for Q).
No 'aerial' required.
GeorgeWatt
Re: Aerial
Thank you for that - my terminolgy was wrong - I was trying to work out if we can 'remotely' connect the Sky dish to the Q Box as Im trying to move my TV from one end of the living room to another without breaking up tiles on the floor/tiled skirting or putting trunking across the walls - but it looks like it might be the latter
This message was authored by bemak187 This message was authored by: bemak187
Re: Aerial
@GeorgeWatt  The dish needs to be phsycally connected to the Q box with the coax cable that runs from the dish down to the box.  No way to do it without the wires.
Re: Aerial
Hi @GeorgeWatt
If the new location is on an external wall then it may be possible to install new cables from the dish.  Sky would do this for approximately £65.
If it is an internal wall then your options are limited.
Re: Aerial
@GeorgeWattYour other option is to looks at Sky Glass or Sky Stream as these have no dish and work over WiFi so less wires although these are a totally different type of service and require a fast internet connection with very strong WiFi.
This message was authored by Invisiblename This message was authored by: Invisiblename
Re: Aerial
Also a full undertstanding of what the differences are in the way they operate compared to Sky Q
I am just another Sky customer!
Re: Aerial
@GeorgeWatt
Some Q users go to the extent of having the main box on the end of its dish cables in a concealed position without a screen, and then use a Q Mini box (over WiFi) with an HDMI cable to the television set.  That does mean giving up UHD output though, and requires the Multiscreen subscription.
