3
This discussion topic has been answered Discussion topic: 3 Network download failure again
This message was authored by: mguk
Sky Q failed downloads after Sky update their software again,.
Connected via ethernet. Wifi doesn't even connect.
This message was authored by: Ecosse Answer
Re: 3 Network download failure again
I'd suggest fully rebooting both the router and the Sky Q main box.
Unplug both of them, same time, from the wall for at least 30 seconds.
Plug back in the router only, get it up and running, and run a speed test on your mobile. Now plug back in the Sky Q box, go to settings, and reset the network settings section. Then scan for your router, add in your password, and hopefully, you're back up and running.
Good luck.
Samsung UE49MU7070XX - Samsung MS550 Soundbar+ with 9000S Rears
Sky Q 2Tb + 3 Minis - BT Full Fibre 900
Good luck.
@mguk there has not been a recent update to the software
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
This message was authored by: Godfrey
@mguk  If you perform several 3 Network download tests, what is the highest latency value that is being reported.
