Discussion topic: is sky mobile compatible in a blackberry phone
Message posted on 29 Oct 2025 10:15 PM
I've just opened a sky mobile account, I've put the sim in my blackberry phone, but doesn't appear to be working. Is Sky mobile compatible with a Blackberry phone? Thanks
Message posted on 29 Oct 2025 10:28 PM
Re: is sky mobile compatible in a blackberry phone
Has the sim been activated as there is no reason why it wouldn't work so do you have another unlocked device you could try it in ?
Message posted on 29 Oct 2025 10:32 PM
How do I know if the sim has been activated? I received an email from Sky saying that I've transferred over and that my Sky Mobile is up n running.
Thanks for responding
Message posted on 29 Oct 2025 10:35 PM
You have to activate the sim via your account so did you do this ?
Message posted on 29 Oct 2025 10:42 PM
I've activated and got my PAC code from my former provider. Handset acknowledges that its Sky, it's got Mobile Networks as Sky
Message posted on 29 Oct 2025 11:53 PM
Hi @DAM47 check the APN in the phone settings.
I AM NOT A SKY EMPLOYEE
All Opinions Are My Own
Message posted on 30 Oct 2025 08:36 AM
@DAM47 Is the Blackberry phone 4G comnpatile? If not it may be 3G and that is being switched off over the country by the end of 2025.
Message posted on 30 Oct 2025 02:18 PM - last edited: 30 Oct 2025 02:26 PM
I'd observe the final BlackBerry handset was released in June 2018 running Android 8.1
