Discussion topic: data roaming
Message posted on 20 May 2025 09:27 AM
							data roaming
My 4g isn't working on holiday
Message posted on 20 May 2025 09:31 AM
							Re: data roaming
Where are you ?
Message posted on 20 May 2025 09:32 AM
							Re: data roaming
I'm in algarve portugal and it was working yesterday and now has suddenly stopped
Message posted on 20 May 2025 09:34 AM
							Re: data roaming
Although you don't have to, do you have a spend cap set because if you do it needs to be high enough to cover your stay.
That apart have you tried searching for other networks to see if your device will connect and then work ?
Message posted on 20 May 2025 09:37 AM
							Re: data roaming
How do i find out if i have a spend cap? And wifi is working and calls are working it's just my 4g/5g
Message posted on 20 May 2025 09:39 AM
							Re: data roaming
If calls are working then it will not be spend cap related so pretty much all you can try is to see if your device will connect and work to a different network.
