Discussion topic: Timing
Message posted on 20 May 2025 08:07 AM
Timing
I want to transfer to Sky Mobile when my contract finishes on 7th June with another provider, when should I order a Phone and Sim card?
Message posted on 20 May 2025 08:37 AM
Re: Timing
Hi @LP27 this would be difficult to answer as the phone you order may be out of stock. Assuming everything is in stock and your contract finishes (have you given your notice to your current network?) on the 7th then ordering on the 5th should get your phone on the 6th. Activate your sim then port your number on the 7th. Your billing starts the day you receive your new phone.
I AM NOT A SKY EMPLOYEE
All Opinions Are My Own
Message posted on 20 May 2025 08:38 AM
Re: Timing
Thank you. Thats very helpful.
Message posted on 20 May 2025 09:00 AM
Re: Timing
@LP27 In addition to the ino posted by @63johnw if you're porting a number from another provider you won't need to cancel the sim p plan with them as a PAC wiull do that for you, I believe you have 30 days to use the PAC from requesting it with your current provider.
