348
This discussion topic has been answered Discussion topic: Phone not working in calls or out calls just disconnecting
This message was authored by: SomersRosyth
Re: Phone not working in calls or out calls just disconnecting
This has been ongoing with us for days people getting wrong number messages and I am unable to make calls
This message was authored by: Jodie124
How long phone going to be down
Since yesterday me and my family have been having trouble receiving and making calls not working at all how long will it be till solved
This message was authored by: Alison695
Advising you are aware of the issue is not a sufficient answer to all of the customers who are experiencing this issue? I would like to know when this will be resolved? And will all affected customers get any compensation for loss of service?
This message was authored by: Shaun+Armstrong
I've not been able to make or receive calls when I'm in my home for the last 3 days having to resort to WhatsApp etc. when will this issue be resolved and will we receive compensation due to unavailability?
This message was authored by: Jules_69
Re: No call network
My neice can't ring out and cnt receive Incoming calls iPhone 16 pro
This message was authored by: Tenchs
Sky mobile connection issues
Currently I am unable to answer or make calls from my mobile each time the call just says 'failed' and if someone tries to call me, they get a message saying the number doesn't exist.
even at home linked to my WiFi I am unable to answer calls.
is there a local issue?
This message was authored by: Sarah_58_
Re: No call network
Same issue with my phone did try turning on off but did not clear the problem.
This message was authored by: Suzzi1
In my case I fixed it by disconnecting from the mobile network, then auto reconnecting. I assume I was connected to a faulting network before.
This message was authored by: annefearman
@Suzi1 I have tried that and it hasn't worked also tried multiple other "fixes" with no luck.  This has been going on  for over 24 hours now.
Re: No call network
@Jules_69
Your duplicate post saying the same has been removed and I see the other two duplicate threads you've started have as well.
This message was authored by: Marksmith30
Re: Sky mobile connection issues
I am having the same issue
This message was authored by: Rharper
Call connection issues - samsung flip
Since yesterday I cannot make or receive calls. I'm notified 'call failed' when trying to ring out. People trying to call says it rings once and cuts off. We have full signal/connected to wifi.
This message was authored by: Mortal
Yep, my incoming and outgoing get disconnected as soon they connect. Have got hospital phoning to book appointments and to talk to consultants. So yer thanks Sky great help you been noootttttt.....
This message was authored by: Moley2
Re: Call connection issues - samsung flip
@Rharper
I have moved your post into a thread discussing this issue that some customers have had for up to 48 hours. See the post currently marked as the answer which can change once there's a significant update.
Answered - Go to Answer
