6
This discussion topic has been answered Discussion topic: Phone not registered on device
This message was authored by: anitaif
My phone has suddenly stopped making and recieving calls, it says network not registered on device
Re: Phone not registered on device
You could order a replacement sim but only if there are no issues showing here for you:
https://www.sky.com/help/servicestatus/your-services/mobile
Are you sure it isn't saying "not registered on network" ?
Avatar for anitaif
Level 2 icon
Re: Phone not registered on network
Yes your right.
Try turning off your phone and removing the sim the gently wiping it before inserting it back in the phone and turning it back on.
Avatar for anitaif
Level 2 icon
I've done that twice now and still says the same thing. Do you think if I get a replacement sim card it might work or is it more likely a problem with the phone itself.
This message was authored by: popcorn1
hat was your resolution, mine has just started doing same thing
