14
This discussion topic has been answered Discussion topic: PAC code
This message was authored by: JA1234
PAC code
I've bought a new sim from sky after previously being with them. A Sky PAC code cannot be used on a new Sky sim, therefore I was told to set up a temporary sim card, transfer my number to that, and then from that back to Sky. I have transferred it to the new temporary sim and it is all sorted and fully transferred. However, when I request my PAC code, it is the same one from my original Sky sim and still cannot be used to activate my new one. I have left it a couple weeks to see if this would change with time but it hasn't. I'm not quite sure what to do as I'm paying for a temporary sim that I've used much longer than I wanted to, whilst also paying for a Sky sim (in a bundle with a new phone) that is yet to be activated. I don't want to lose my number however, as it would be a lot of work to change my details on many accounts. Any help would be greatly appreciated.
This message was authored by: 63johnw Answer
Re: PAC code
No problem, no apologies needed @JA1234  definitely come back if you need more help.
I AM NOT A SKY EMPLOYEE
All Opinions Are My Own
Re: PAC code
Hi @JA1234  have you activated the new sim ? What's happening when you try and use the PAC ?
Avatar for JA1234
Re: PAC code
@63johnw
I've not activated it yet as whenever I go to and say I want to keep my number, it requests a PAC code. When I use the code, it says "Sorry, you cannot use a PAC code for an existing Sky Mobile number." Eventhough the old sim has since been erased and the number transferred to a company that isn't Sky.
Re: PAC code
I would activate the new sim @JA1234  then once activated try the PAC code. Porting can't happen at weekends so wait until Monday before trying to use the PAC code
Avatar for JA1234
Re: PAC code
@63johnw
How would I go about keeping my number? As if I don't have a PAC, it'll request a STAC. Would this not stop my current number from being able to be transferred?
Re: PAC code
Not sure what you mean @JA1234  ? Your new sky sim should be able to activate ? What happens when you say you want to activate it ?
Avatar for JA1234
Re: PAC code
@63johnw
When I go to activate it, it appears with 2 options - "I'd like a new number" and "I want to keep my number". The keep number option is what I've been trying but the PAC code isn't accepted as it still says it is a current Sky number, eventhough I have transferred it to a temporary one. The other option requests a STAC which I believe would cancel my phone number which I want to keep.
Re: PAC code
It should be the first option @JA1234  requesting a new number. You shouldn't need to use a STAC. If it's asking for that then post back on here and we can see if we can get you some help (will be tomorrow now).
Avatar for JA1234
Re: PAC code
@63johnw
I have looked further into it and I think it may be a problem on the current provider of the temporary sim. If this is the case I deeply apologise for the time wasted. However I very much appreciate the help. I shall try sort it on Monday and will provide a response then 🙂
Re: PAC code
Avatar for JA1234
Re: PAC code
Hey @63johnw ,
My sim is all set up now, got a message saying my number will be transferred on Wednesday. The issue was with the temporary sim not the sky one. Thank you very much for the help, all the best 🙂
This message was authored by: Mupfumira
Re: PAC code
I asked for a pac code then I was sent  imail with a codeI phone again to sky I was told to go to my sky to retrieve my pac code
Re: PAC code
@Mupfumira
This link explains how to send a text with the Sky sim in your phone if you want to transfer your number from Sky to another provider:
https://www.sky.com/help/articles/switching-mobile-providers-leaving-sky-mobile
This message was authored by: Debbie282
Re: PAC code
How long does it take for your mobile number from your old provider take to transfer to sky mobile
Re: PAC code
@Debbie282
Usually within a day or so unless you give Sky the pac code on a Saturday or Sunday as this will be the same as if you gave it to them on a Monday.
