6
This discussion topic has been answered Discussion topic: Sky plus not supported
This message was authored by: Finwhale
Now Sky+ app  is no longer supported so no grid appears, how can I schedule a recording on sky go it only shows the current programmes unlike the grid option I used to use. Is there no way of seeing future programmes.
Re: Sky plus not supported
You can use Sky Go as you did with Sky+, find the program either by either searching for it or using the TV Guide if you know the day and channel it is on.
@Finwhale  Sign in and try this link
Tv guide
Avatar for Finwhale
Level 4 icon
That's great thank you very much Sky Go TV guide works ok on a tablet but you don't get the full TV guide on iPhone only for the day in question which is a bit disappointing the old grid showing programmes in coming days.
Avatar for Finwhale
Level 4 icon
Great thanks that works
This message was authored by: Thompson28
The  sky+ app is no longer available to downloadand and there is no TV grid view in the Sky go app TV guide but if you open the Sky go app then scroll down to the channel you want to remote record from and click on the text to the right of the TV picture then click on Today at the top of the screen it will open a drop down menu for the next seven days for that particular channel, click on the day the programme you want to record is aired, scroll down to your programme and press the record button to bring up either record once or record series at the bottom of the screen.
Avatar for Finwhale
Level 4 icon
I tried this on the sky go app on the iPhone that doesn't work there is no text are you referring to sky go on a tablet ? Thanks
