09 Mar 2024 11:30 AM
Now Sky+ app is no longer supported so no grid appears, how can I schedule a recording on sky go it only shows the current programmes unlike the grid option I used to use. Is there no way of seeing future programmes.
09 Mar 2024 12:27 PM
Posted by a Superuser, not a Sky employee. Find out moreYou can use Sky Go as you did with Sky+, find the program either by either searching for it or using the TV Guide if you know the day and channel it is on.
09 Mar 2024 11:33 AM
Posted by a Superuser, not a Sky employee. Find out more@Finwhale Sign in and try this link
10 Mar 2024 07:24 AM
That's great thank you very much Sky Go TV guide works ok on a tablet but you don't get the full TV guide on iPhone only for the day in question which is a bit disappointing the old grid showing programmes in coming days.
10 Mar 2024 07:27 AM
Great thanks that works
12 Sep 2024 12:52 PM
The sky+ app is no longer available to downloadand and there is no TV grid view in the Sky go app TV guide but if you open the Sky go app then scroll down to the channel you want to remote record from and click on the text to the right of the TV picture then click on Today at the top of the screen it will open a drop down menu for the next seven days for that particular channel, click on the day the programme you want to record is aired, scroll down to your programme and press the record button to bring up either record once or record series at the bottom of the screen.
12 Sep 2024 03:06 PM
I tried this on the sky go app on the iPhone that doesn't work there is no text are you referring to sky go on a tablet ? Thanks
On average, new discussions are replied to by our users within 3.6 hours
