29
This discussion topic is read only This discussion topic has been answered Discussion topic: Bitdefender detecting Malware and blocks Sky Go on PC
This message was authored by: PJSwaff
Im a bit confused as to whats going on but when I went to open Sky Go on my desktop PC tonight, Bitdefender went a bit crazy and no matter what I tried, there is no way it will let me open it.
I use Sky Go numerous times every day and never had an issue till now.
I have included screen grabs to show whats going on and was wondering if anyone else that uses Bitdefender Total Security has had the same problem.
PJ
Sky Go Malware2.pngSky Go Malware2.pngSky Go Malware1.pngSky Go Malware1.png
This message was authored by: Chloe-W22 Answer
Re: Bitdefender detecting Malware and blocks Sky Go on PC
Posted by a Sky employee
Morning all,
Thanks to this thread, we managed to liaise with Bitdefender who updated their software and it should now be identifying Sky Go correctly. If you're still having issues please update your Bitdefender software 🙂
Chloe-W22
Sky Community Manager
Have a story you want to share with us? Send your Thanks to Sky here
Locked
Perhaps it is worth uninstalling it then downloading a fresh copy from the Sky website so see it it will then open.
Uninstall the Sky Go app and then go to 'C:\Users\[your user name]\AppData\Roaming (ensure hidden files/folders are visible) and delete the following folders:
Sky
Sky Go
And if it is present (it might not be) the Cisco and/or Synamedia folder in App\Data\LocalLow.
Empty your recycle bin.
Reboot your PC and then download and install the Sky Go app again via here:
https://www.sky.com/watch/sky-go/windows
This message was authored by: Hamilton
My bitfender is doing exactly the same thing today, with my Sky app. So weird! I reinstalled the sky app.. And bit defender automatically deletes the app, after it downloads, sayings it's unsafe!
This message was authored by: MotoFox994
My Bitdefender is also detecting malware in the latest update.
Great timing, just in time for the Champions league final! 😂
@PJSwaff @Hamilton @MotoFox994
It's far from unknown for AV products to occasionally misidentify legitimate software components as hostile ones: typically the vendor fixes this in the next signature update.
Well i also have the same warning linking Sky Go with Trojan software
Gen:Trojan.Heur.Hype.iB4@a8ZmfHki
https://imgur.com/a/SSf8e5B
The apps team are the people to inform about this - [email protected]
Quite possibly, but when all such reports are from the same AV provider and no other such product is mentioned, that's a clue.
This message was authored by: AncientYouth60
my sky go app is going the same way with Bit Defender , on the phone is fine
Yeah thats the evidence that highly likley means its an issue on the BitDefender end and they are incorrectly detecting Sky Go as a virus. If there was some bigger issue with Sky Go we would be seeing reports of lots more anti virus software detecting it.
This message was authored by: RoryQ92
I've got the same issue.
A trojan is detected when I try to install SkyGo.
I've tried to talk with italian chat support and they told me that I've a virus on my pc and that I don't have to talk to them, I've to clean my pc and then install SkyGo. (Really? I think they didn't even understand what I was saying).
So I've send an email to uk app's support asking why Bitdefender is detecting a trojan inside the installer and they just replied "Turn off your antivirus, install skygo and then turn is on again".
Doesn't seem safe at all.
This message was authored by: Gianka
I'm in the same situation except that the BD people in chat asked me for a syslog of my PC to send... Boh...
I recently upgraded my PC to Windows 11, could this have anything to do with it?
I have windows 10 on my laptop and windows 11 on my desktop computer both with BD. I've got the same issue on both.
A friend of mine had a previous version of sky go on his laptop with BD and this morning he tried to update and it didn't work. Now the app doesn't work anymore.
This message was authored by: stephenedinburgh
skygo issue
 I am not able to open skygo as my Bitdefender flags a trojan.
Is anyone able to help?
Bitdefender detected potentially malicious behavior and blocked all applications involved. Detection ID: Gen:Trojan.Heur.Hype.iB4@a8ZmfHki
Locked
