6
This discussion topic has been answered Discussion topic: Box Sets
This message was authored by: DB68
Box Sets
I do not seem to be able to access the box sets option on my sky glass menu
This message was authored by: lettice Answer
Re: Box Sets
In your voice remote say 'Cosmic code'
That will find it, it's available to download now for S1 e1, 2 and 3
Its on Sky History channel to watch at 9 pm today.
Its called Bradley Walsh: Egypt's cosmic code
Re: Box Sets
Box sets aren't really a concept on Sky Glass because everything on demand is integrated and discoverable through the menus.
What show are you looking for? Try saying it into the voice search and it should take you straight to that show page. Or try "comedy shows" or "Sky Atlantic shows" to find them.
Or the TV Shows tab at the top of home is also a good way to discover shows and if you go down you should be able to find buttons for the key Sky channels to see what's on demand on those.
Avatar for DB68
Re: Box Sets
I was looking for Bradley Walsh Cosmic Code which does come up but I was unable to watch any of the box set. It just showed it starting this evening.
Re: Box Sets
Avatar for DB68
Re: Box Sets
Hi, I tried that yesterday and it showed me it was available at 9:00pm today but did not show it as available to watch. Have not tried it today but maybe it is not available until the first episode has been shown? You say available to download, but you do not download anything with Sky Glass!
Re: Box Sets
@DB68 I've checked mine and just above "On this week" are thumbnails for three episodes, all of which are available to play now by pressing select on them.
If you're not seeing this, can you confirm if you're on the Essential TV or Ultimate TV package? Can you watch Sky History live on channel 115?
Avatar for DB68
Re: Box Sets
I am seeing that this evening, but they did not appear yesterday. Thanks for your help with this issue.
Answered - Go to Answer
