This discussion topic has been answered Discussion topic: Sky TV technical fault
Message posted on 15 Sep 2025 10:33 PM
My broadband is on and working but it states a technical issue for sky TV and they are working on fixing the issue, it's not been working for 3 days. I thought may be a bad connection.
Message posted on 16 Sep 2025 06:34 AM - last edited: 16 Sep 2025 06:45 AM
Have moved/combined some posts of this technical fault on Sky Glass and Sky Stream that occurred last night.
Did see a small blip for a few minutes last night on my Sky Stream around 9:30pm
A quick Puck settings restart sorted the issue for me.
Assuming it was just a small blip last night that affected some customers and all of you in this thread are now all running fine this mornin
If any of you are still seeing the issue this morning, please start a new post with your issue, as it may not be related to last night problem.
Will make this the answered post for reference.
Message posted on 15 Sep 2025 08:02 PM
Sky Glass Issues
Anyone experiencing issues, I have Sky Glass Gen2, issues with speaking to the remote and any voice commands, they work for a few minutes and then everything starts to lag, slow between menus and blue screen with please wait.
Have put TV on standby and rebooted multiple times, switched off router and reset. Internet speeds look fine at 140mbps.
Also reset control with the commands 1-3 and 7-9, commands very much on and off but everything is so slow.
any ideas please, tried calling Sky and it just says busy and they hang up.
Sky Air 43" in bedroom
LG 65" TV with Puck in spare room.
Broadband with Seethelight as on new build estate that does not support Sky.
Message posted on 15 Sep 2025 08:27 PM
Re: Sky Glass Issues
My Sky glass tv gen 2 is working fine gigafast broadband 900mps full fibre to the property
Message posted on 15 Sep 2025 08:45 PM
Now having issues watching anything, one minute it works then drops in and out with a black screen saying programme is loading or technical fault.
Rang Sky I got told to ring another number who directed me back to the number I rang previously. Had enough now.
Message posted on 15 Sep 2025 08:58 PM
Stuck on loading … then says technical fault.
Suddenly tonight - tried to switch channel and got stuck on loading message. Then said technical fault. Tried switching off at socket and leaving for a minute or so and switching back on. That resets it but happens again the minuté I try to select a channel. I can successfully get to and watch Netflix. Broadband (not Sky) fine. Any ideas?
Message posted on 15 Sep 2025 09:04 PM
You only have 140mps and the more devices that you have connected the weaker the signal is to each device, 140mps is what you get to the router not what you get to each device, sky glass tv to watch hd channels you need a minimum of 25mps and to watch uhd channels you need a minimum of 35mps that is what sky recommend for each sky glass tv and puck, if you have mobile phones, laptop games consoles or anything like that that will eat into the Internet speed, run a speed test by opening Netflix going to help opening that and running check my network and see what speed each tv and puck are getting
Message posted on 15 Sep 2025 09:06 PM
Re: Stuck on loading … then says technical fault.
I'm having the same problems.
Sky glass all channels showing technical issues
All channels showing technical fault
Message posted on 15 Sep 2025 09:08 PM
Message posted on 15 Sep 2025 09:10 PM
I would say that you probably need a minimum broadband of at least 500mps to sort your issues out, i have 2 55inch sky tvs a puck, sky live camera, freesat box, Xbox, laptop personnel computer, 3 mobile phones a smart meter, 3 alexas
I am on gigafast broadband 900mps and have no problems with freezing tv or anything, i would say your broadband is not powerful enough for what you are doing, as I have said the more you have connected to the Internet the weaker the wifi signal is to each device
Message posted on 15 Sep 2025 09:16 PM
I've restarted the device from the setting menu on the device, I have the channels back for now, see how it's lasts. It's the 2nd time this evening I've had to do it.
Message posted on 15 Sep 2025 09:29 PM
Changing channels
Every time I try to change channel I'm met with'technical fault'. The only way to change is to turn stream box and pick channel from home page
Message posted on 15 Sep 2025 09:39 PM
I have never had these issues before, and I have two glass TVs, a sky puck that my daughter doesn't really use and then just phones connected.
I've tried my Glass Air upstairs with no issues so will monitor the TV downstairs for a few days to see if it was an internet issue
Message posted on 15 Sep 2025 09:51 PM
Re: Sky glass all channels showing technical issues
Bloody joke sky streaming regularly freezes and stops working worst thing I ever did sky are a joke
Message posted on 15 Sep 2025 10:08 PM
Technical fault
I keep getting the message there is a technical fault at the top of my screen I have sky glass and the oil in the bedroom this is getting so annoying I have unplugged it several times lasts 20ins and comes back up anybody got any ideas what is causing this
