This discussion topic has been answered Discussion topic: Sky TV technical fault
Message posted on 16 Sep 2025 09:08 PM
Re: Sky TV technical fault
Ours has been working fine through the day, but seems to be issues using the remote and the voice, with the outages last night did anyone else have problems with the voice?
Doesn't seem to be picking much up tonight either but the channels are working.
Sky Air 43" in bedroom
LG 65" TV with Puck in spare room.
Broadband with Seethelight as on new build estate that does not support Sky.
Message posted on 16 Sep 2025 09:49 PM
Technical fault for 2 days now
Yesterday evening and this evening my to keeps dropping out and displays that there is a technical fault. I am continually having to reset by turning off and then on again. Am really fed up with this now. Getting Sky Glass was the worst decision. Can anyone help with how to get a resolution to this problem?
Message posted on 16 Sep 2025 09:58 PM
All channels technical fault since 21.05
All channels say technical fault try again later has been dong this since 21.05 nothing helping
Message posted on 16 Sep 2025 10:11 PM
Re: All channels technical fault since 21.05
The same
Message posted on 16 Sep 2025 10:14 PM
Message posted on 16 Sep 2025 10:15 PM
Technical Fault Try Again Later
Message posted on 16 Sep 2025 10:17 PM
Tried everything giving up now time for bed lol
Message posted on 16 Sep 2025 10:56 PM
Mine has a technical fault on all channels. Home Screen is fine but can't watch anything. Have tried all the regular fixes like turning off at plug for a minute and then turning on again. Have also tried turning the router off and then on again after a minute. Nothing is working.
Message posted on 17 Sep 2025 05:57 AM
Re: Technical fault for 2 days now
Same here. One issue after another. Bad decision to buy Sky Glass Air!! And trying to contact Sky is just one huge obstacle to trying to get an engineer
Message posted on 17 Sep 2025 05:58 AM
Re: Technical Fault Try Again Later
Sky support is no help. And don't get me started on that silly 'chat' thing that appears!!
Message posted on 17 Sep 2025 09:54 AM
@Rum230 there's no engineer support for Sky Stream. What did Sky suggest when you contacted them?
Message posted on 17 Sep 2025 02:47 PM
Haven't contacted them yet as still looking for a phone number.
Message posted on 17 Sep 2025 09:16 PM
Me too. Only Netflix works on my sky puck
