4306
This discussion topic is read only This discussion topic has been answered Discussion topic: Sky Glass Power up Issues 19-9-24
Locked
Re: Streaming has been down for 4 days spent over 4hrs on the phone keep getting disconnected
@Ttttt wrote:
I don't want anything to do with them, I'll cancel my direct debit if it's not fixed by tomorrow
As @Daniel0210 notes this isn't going to get the result you want.  (Very much to the contrary)
Of course, you are welcome to ignore this advice.  The correct way is to give the correct notice to cancel.  Note that if you are subject to a minimum term then this could involve early termination charges.  If a credit agreement is involved then you may be required to pay the complete balance immediately.
This message was authored by: DuckieBoos
Re: Sky Glass Power up Issues 19-9-24
It’s clear looking on X & the forums that the troubleshooting for sky stream & glass not working doesn’t work for everyone. Also what are sky doing to support the elderly & disabled who cannot physically do what Sky are asking of them to fix a fault Sky themselves most likely caused? At any rate we are all customers not Sky engineers.
This message was authored by: Peanut68
This doesn't work for my glass other than it powered it up again my issue is activation isn't working now it's on my account and active but tv won't go past activation I've done the reset about 25 times now and all I've got is bog standard tv.
This message was authored by: jamieblue
My mums sky stream puck has been out of action since Thursday, i carried out the recovery process which worked on Friday and ever since i have been trying to re-activate the account!!!
Sky.com/activate page is down and no one seems to be answering phones, the virtual assistant just keeps asking what account i want to discuss, all i want to do is put the activation code in??
Every time i try to fix this i have to go to my mums because the activation codes change frequently, this is a joke!!
@paulb2024 wrote:
Hi,
My Sky glass is still not working. It has been like this for 4 days now. When are you going to get this so called outage issue resolved.
A complete lack of customer service as usual from Sky. Will be cancelling my subscription when this is resolved....Shambolic
@paulb2024 have you followed the steps as instructed in the post marked as the answer in this discussion? These are the official resolution steps provided by Sky.
Avatar for GD1
Level 16 icon
@jamieblue  Have you logged into your Sky account before going to the activation link?
Have your tried using a different browser or using private/incognito mode?
You could also try the My Sky app.
This message was authored by: Mellissa7714
Skyglass
Hi, anyone in the Broxburn/uphall area having issues with there sky glass or work for sky ? I know they are having issues at the moment I have managed to get my tv on by resetting it as was stuck on standby but now my tv will not connect back to my ee wifi.
I have waited a total of 2 hours and still can not get through to anyone at sky as usual.
Can anyone help Thanks
This message was authored by: Yelselh
Sky Stream TV still not working
Sky Stream has been out for 2 days now. Whats going on!?
Re: Sky Stream TV still not working
Have you followed the steps here: https://www.sky.com/help/articles/sky-glass-stream-wont-turn-on ?
Avatar for GD1
Level 16 icon
@Yelselh  If you have not already done so have a look at the Answer (post 2) and follow this link https://www.sky.com/help/articles/sky-glass-stream-wont-turn-on for the recovery process. It has not worked for all subscribers
Most people who have an issue seem to get stuck at either the PIN or activation steps. If asked for a PIN just ignore it and unplug your Glass TV and then plug it back in again after about 30 seconds. After it reboots you should be able to continue the recovery procedure.
When you are aske to enter an activation cove ensure you are logged into your My Sky account or you will get an Oops..... error message.
This message was authored by: Jporch316
Re: Skyglass
 Antony connect with an Ethernet cable temporarily to get you up and running ?
also you may want to pull the plug on your router for 10 mins
43inch Gen 1 and 55 inch Gen 2 Sky Glass & sky live camera 3 Pucks. Virgin media M350 hub 5x. Four sky mobile sims.
This message was authored by: HuwJames
My Sky glass tv has not been working since Friday.
My Sky glass tv has not been working since Friday.  I have tried the suggestion online to hold the reset button whilst turning the power on.  But that doesn't work either.  Seen on the BBC website that this is a national problem not just me!  Tried calling the Sky helpline Friday, Saturday and today but give up after an hour each time.  Useless service from Sky.  No help no nothing!  Can't even play DVDs' on the tv.
Will be going back to conventional tv after this and cancelling my Sky tv.  Lousy service!  Not impressed!
Hi, I have tried that multiple times nothing works.
@BobW2 wrote:
I would like to add my thanks to  the non Sky employee Superusers giving advice here,  appreciate the time and effort they are giving trying to  help  people.
Thank you.
We as Superusers and customers like yourselves, do appreciate kind comments like this.
This message was authored by: Aslamshaikh58
Re: Where to put activation code for sky stream
Where I link my account and enter my code
Locked
Answered - Go to Answer
