4306
This discussion topic is read only This discussion topic has been answered Discussion topic: Sky Glass Power up Issues 19-9-24
Locked
This message was authored by: horace
Re: Any updates on stream outage?
@revird wrote:
I switched my plug on the wall held the reset button in longer than they suggested it came back on just followed the on screen instructions all working now and it switched on this morning hope this may help some of you
Glad to hear you are sorted.
I also found that holding the reset button a bit longer than recommended proved to be the difference between failure and success. It's important (with a stream Puck, at least) to wait until the lights are flashing multiple colours.
This message was authored by: chasanne1
Re: Sky Glass Power up Issues 19-9-24
Just a thought I am in Norfolk and got streaming last Wednesday and conected to my router by ethenet cable. Puck started first time no issues since only thing it did not do at start was an update which seemed odd apart from that all OK.
Any one in Norfolk with no streaming?
This message was authored by: Tvwatcher1
Re: Sky steam puck keeps turning on and off by itself
Eventually (like a few days after the puk being plugged in) the lights started flickering red and green and the sky made me reconnect my remote and wifi. It's working now again.
Re: Sky stream box not working
@Kirsty7777 wrote:
My sky glass and sky stream both went down on Thursday night. I have now reset my sky glass TV by following the instructions online and it is working downstairs, however, the sky stream upstairs will not reset. I have tried to reset sky stream by holding the on/off button for 20 seconds until the box flashed and then the screen turns blue, text appears asking me to hold the 4 and 6 button together. My tv is not responding to this and I can't get past this point. Is anyone else having the same problem? @Skyglass @SkyStream
Try pointing the remote when doing that at the Sky stream box, not the TV and get as close as possible to the Sky Stream box as you can when doing it.
This message was authored by: RachelHadley
Sky puck activation code
Followed set up on scream. Now have an activation code but have no clue where to go to activate as the sky.com/activate just comes up with an 'Oops something went wrong' message. H E L P!!!!!
This message was authored by: BobW2
Managed to reset my  puck and get servicesback  yeserday lunchtime,  now  goine down  again.  Grrrr.
Anyone have else have this issue?
Re: Streaming has been down for 4 days spent over 4hrs on the phone keep getting disconnected
@Ttttt wrote:
I'll cancel my direct debit if it's not fixed by tomorrow
@Ttttt
Very unwise. Cancelling your payment method will increase your problems. Sky services (when this is fixed) will be restricted, late payment fees will be added, you won't be able to speak to Sky, you won't be able to cancel and continued non payment will result in Sky passing the debt to a Debt Recovery company which will ultimately affect your credit score.
This message was authored by: Sugar2024
That's exactly what I'm going through and am now on hold for nearly half an hour waiting for someone to answer my call!!
This message was authored by: Kdoodle
Re: Sky puck activation code
That what's happened to me in several ocadsimsn and even when I log into my sky app, it still won't activate. Very poor service and dissapointing.
This message was authored by: Kirsty7777
Re: Sky Stream still not working......
Hi, yes I have followed the steps carefully for sky glass downstairs and sky stream upstairs, sky glass is now working but sky stream is stuck on the page where it asks to hold the 4 and 6 numbers together for 2 seconds on the remote. This is not doing anything at all, my remote has new batteries and Is working fine too, I cannot get past this step. Thanks.
This message was authored by: JaqiT
Skygkass television still not working i am unable to join code to my account
Can you please give us an update on skyglass I have followed instructions to reboot but can't enter code to account
Try holding the remote very close to the remote sensor on the puck, as it relies on old school infrared until paired.
Worth a try if you haven't already.
Good luck.
@RachelHadley  This Oops error message is often a sign that you are not signed into your My Sky account  at  https://www.sky.com/mysky  If you think you are signed in then try signing out and back in again.
Once logged in go to https://www.sky.com/productsettings/streaming-tv/activate This is where you should be able to enter your activation code.
During setup you must also be using the same email that is registered to your account.
This message was authored by: Brian225
Yes, for the third time in as many days I have tried the recovery process and its still not working.....
This message was authored by: ClareP123
Re: Sky Glass and Stream Pucks - Won’t load the home screen beyond a blue refresh screen
I've tried the reset/recovery process multiple times and it's still not working. It's been out since Friday!
Locked
Answered - Go to Answer
