3221
Discussion topic: Sky Glass Power up Issues 19-9-24
This message was authored by jimmcghee This message was authored by: jimmcghee
Why is sky glass working with other broadband providers but not sky?
Our sky glass has been down since Thursday. We know there was a national outage but, subscribers in alternative broadband providers aren't affected. Why? We've tried everything sky has suggested but can't get past the postcode page so can't link our accounts. We've been sky subscribers for 25 years and the details in our sky I'd holds the postcode we are inputting.
This message was authored by Kdoodle This message was authored by: Kdoodle
Re: Sky Glass Power up Issues 19-9-24
Still noy
jpy for
me with my stream/puck - trying the recovery process again...updating software part this far!
This message was authored by roger1949 This message was authored by: roger1949
Re: Stream/Puck not working - PIN reset also not working
Sky are working hard to improve the problem,in the meantime keep reading the superusers repeat the same message for 190+pages even though not everyone has the same issues.
This message was authored by Lesley07 This message was authored by: Lesley07
How do you create a mobile hotspot on an iPhone  please
This message was authored by lettice This message was authored by: lettice
Re: Sky puck flashes white then turns off.
@Bumpa73 wrote:
I've done the reset prodedure in Post 2 about 4 times but keep getting stuck ona "Remote control setup" step.  I hold the 4 and 6 buttons but nothing happens and I cannot click the "Continue" so jsyt get stuck at this step.  Any thoughts anyone???
Seen this one before, hope it works for you.
Tirn off your puck or Glass TV, not sure what you have.
Do the  4 and 6 as you have previously then do this:
Press and hold 7 and 9 together for at least 3 seconds.
Then try the fix procedure again.
Sky Community Superuser
Sky Stream (2 pucks), Sky Ultrafast + using Sky SR203 hub. Sky Protect kit tester.
This message was authored by Chrismurr80 This message was authored by: Chrismurr80
Re: our 65inch sky glass will not turn on
On page 2 there is a walkthrough to get it working.
Turn the mains plug off. Hold down the power button on the side of the tv and turn mains back on. hold power button down until the red light starts flashing on your tv, then follow the screen prompts.
This message was authored by revird This message was authored by: revird
done all that still not working
  1. Go to Settings > Mobile Data  Personal Hotspot or Settings  Personal Hotspot.
  2. Tap the slider next to Allow Others to Join.
This message was authored by TomAg This message was authored by: TomAg
Anyone found a fix for getting past the "Oops there seem to be a problem" page so I can enter code and link account have tried clearing cache, using private browser, using telephone data all to no avail.
 Spoke to a Sky agent yesterday after over an hour on hold was no use whatsoever, only had Sky stream installed on the 5th wonder if this will allow to end contract?
Re: Linking to sky account
It's getting stupid now! I really think Ray sky should at least have to decency to update its customers.
I got past that bit but could not enter a one time code...and the it "stuck"
This message was authored by Tj6644 This message was authored by: Tj6644
Still got no Tv . Tv won't turn on . Done as they say on link sent . But nothing. Got no lights on tv or any messages come up . Not good enough two days with no tv
This message was authored by Garseys This message was authored by: Garseys
Reset everything and still have no Live TV or apps on our Sky Glass. Followed steps outlined on page 2 twice with no luck.
This message was authored by K92 This message was authored by: K92
Re: Sky streaming issues
Hi
I must have been lucky because my advisor told me just to switch it off, so that has been overnight and on seeing some suggestions it had been fixed, tried again and it just came on without a re-set!
This message was authored by Lisa2774 This message was authored by: Lisa2774
Re: Sky stream still not working.
I am in the same position!!
