3355
Discussion topic: Sky Glass Power up Issues 19-9-24
This message was authored by lettice This message was authored by: lettice
Re: Sky puck light just flashing
@TDevs wrote:
Having exactly the same issue. Absolutely fine yesterday, turned it on today and have been unable to solve the problem even after following all of the rest guidance.
This is the resolution that works, that you have to do.
It has worked for many Sky Stream and Sky Glass Tv customers over the last three days with the issue.
Follow the procedure exactly as described in post 2 of this thread, flagged as the Answer post from Sky.
Try holding down the button for as long as possible, it won't harm keeping it pressed longer than mentioned, but release when you see the blue screen instructions on screen.
https://helpforum.sky.com/t5/Sky-Glass-Live/Sky-Glass-Power-up-Issues-19-9-24/m-p/4757859#M147519
If you have any issue with activation during the process or entering the pin do the following;
Activation problems:
Try refreshing your browser cache or try the activate link in another browser or device.
Before clicking on the activate link, log in to your MySky account first.
Also, try this alternative link;
Make sure you have logged into your Mysky account in your browser before trying.
https://www.sky.com/productsettings/streaming-tv/activate
Also, you could try using a mobile phone, not connected to your home broadband.
Pin problems:
When at the pin stage and it fails.
Remove the power from your Puck or Sky Glass TV,  leave off for a few minutes and repower.
It will continue, follow the instructions.
This has worked for many having a pin issue
Sky Community Superuser
Sky Stream (2 pucks), Sky Ultrafast + using Sky SR203 hub. Sky Protect kit tester.
Re: Sky Glass Power up Issues 19-9-24
@Dee2024 wrote:
I am having the same issue
not sure what you have tried so far.
It has worked for many Sk6 Stream and Sky Glass Tv customers over the last three days with the issue.
Pin problems:
This message was authored by Mark39 This message was authored by: Mark39
Re: My glass tv has frozen
@Peter261 wrote:
My glass tv has frozen after a reboot have had nothing for 2 days can anyone help
I've moved your post here as it's not related to Sky Yahoo Mail where you originally posted. To get your Glass up and running again, follow the recovery procedure in the post marked as the Answer: https://helpforum.sky.com/t5/Sky-Glass-Live/Sky-Glass-Power-up-Issues-19-9-24/m-p/4757859#M147519
Re: Your product is **bleep**
@Jet1973 We're customers here, not Sky personnel. I've moved your post as it has nothing to do with Sky Yahoo Mail. Have you completed the recovery procedure explained in the post marked as the Answer here?
This message was authored by Cee_Me This message was authored by: Cee_Me
Re: How do I speak to a human sky technical assistant to find out whats happening with sky glass,
It's not just sky glass it's sky stream as well
This message was authored by grainger1982 This message was authored by: grainger1982
Glass won't turn on
 Cancelled my Sky subscription and during the night on Friday our tv and internet stopped working. But for some reason the Sky Glass won't turn on at all. No red light at all on the tv. Tried turning on using remote and power button on TV. Have unplugged and plugged back in. I was hoping to use the Glass TV as a normal
TV from Monday when my EE broadband and TV starts. But I am concerned TV is broken? I have turned on my Nintendo Switch as I though maybe it needs an input to power on but still nothing! Feel like too much of a coincidence to stop working the same day that the Sky was cancelled? Any ideas?
Correct.
This message was authored by Poppy6r This message was authored by: Poppy6r
21st at my 15:37 and still my TV won't work.
Day 3 😭
When you call sky customer service you just sit in a queue for hours, really bad customer service I've tried it for two days now and no luck
@kharis wrote:
Yet another post from Sky saying follow the prescribed procedure and my TV will re-set and turn on.
I followed step by step and guess what - NOTHING HAPPENED !!!. My tv set still wont respond.
So now what Mr Engineer ???  Just wait until how ever long it takes. Think I will ditch Sky
All we can offer is to say, keep trying.
We have seen a few over the last few days that it took about three times doing the procedure to get it working.
Day 3 😭
Have you completed the recovery procedure?
Yup. Umpteen times. I've spoken to three reps.
last one told me I have to wait until problem is fixed as I only have the glass TV and not a sky package 🤷‍♀️
This message was authored by Piker20 This message was authored by: Piker20
Re: Sky Glass Outage
Bet they won't class it as a break of their contract. I feel like cancelling my direct debit because SKY have failed on their half of the agreement
This message was authored by Ric74 This message was authored by: Ric74
@Coops thanks for the alternative method via the app, but I only got as far as device management and THEN got the "Oops there has been a problem" message.
So far I have not seen any evidence that there is a working activation page.  And yes, before you ask, OF COURSE I AM LOGGED IN!!!
Forget about "Post 2", it might work for some but not here.
@TD79
There have been some issues where in the past some customers have had issues with their Sky account, as they have had two accounts and swapped them or similar at some point.
Do you know if you have had anything like this in the past?
If so, you may have to call Sky to get them to resolve the Sky id  and the account activation.
But, if that is not the case and you really do not want to be sat on a long queue to Sky, have you tried doing the activating using a mobile phone on 4g, so it's not connected to your home broadband, that has worked for some.
