20 Sep 2024 02:54 PM
@Hyper1979 wrote:
The "fix" is just a workaround that is only sorting out some devices, not all.
You need to start coming up with some other solution(s) asap!
The procedure isn't a 'workaround': it's a hard reset which manually initiates a software download. If the initial problem has rendered the televisions and pucks unable to have software pushed to them, it's difficult to see what the 'other solution(s)' might be other than hardware replacement, which obviously has a much longer timescale.
Can't get past network setup. No TV since last night. Should of stayed Q box so much more reliable. On hold again to Sky third time with waiting for 1.5 hours. Sky suck!!!!!
20 Sep 2024 02:55 PM
@Hyper1979 wrote:Seriously, this is ridiculous now.
My puck has been down for (closing in on) 24 hours. I've done the "fix" several times and it hasn't worked. The "fix" is just a workaround that is only sorting out some devices, not all.
Follow the procedure in post 2 of this thread, flagged as the Answer post from Sky
https://helpforum.sky.com/t5/Sky-Glass-Live/Sky-Glass-Power-up-Issues-19-9-24/m-p/4757859#M147519
20 Sep 2024 02:56 PM
But why would it be a hardware problem when it was working perfectly fine until sky did something like always?????
20 Sep 2024 02:57 PM
Sky glass 55inch down since 4.30pm yesterday. Resets not working. Cannot connect Xbox anything. It's a joke if I knew then what I know now I wouldn't buy Glass again. Soon happy to put my bills up. But cannot sort this out
My sky stream is working fine however my internet is really slow on my devices I have restarted it but it is still the same. Is everyone experiencing the same thing
20 Sep 2024 02:58 PM
Had the exact same all day
20 Sep 2024 03:00 PM
Yes, and I have done this hard reset several times (as have many others) and it's obvious from the posts on this thread that it isn't some universal fix.
20 Sep 2024 03:01 PM
NOTHING WORKING NOBODY ANSWERING PHONE
When doing the service check on the app it is saying that it is working fine however I'm so confused. I have a couple in uni meeting and work to do but can't see anything as the internet is caying no connection but in the box and my WiFi it says it's working. Is there anything I can do to fix this
Have successfully logged back in by persevering with the holding down the standby button on the TV whilst plugging it back in, not easy with only 2 hands and some distance between the TV and the plug. The setup isn't easy, you need internet access on another device and your master account to verify, ( took me 3 attempts).
The whole thing is pretty shambolic, and here's the big rant, checked my Apps.... Netflix login okay..... AND NOTHING ELSE. having now to find passwords for 6 or 7 other app logins.
20 Sep 2024 03:03 PM
20 Sep 2024 03:04 PM
Still no sky glass and still can't watch anything I hope you take some money of my bill please why paid for something when can't used it
20 Sep 2024 03:07 PM
customers need to register their complaints with Ofcom the more sky customer that do this the more they will be held accounable in the end and for compensation i registered my complaint this morning andxwas given a reference number for the logged complaint for bad sky customer service and no communication /updates .
