22 Sep 2024 04:22 PM
Have had no TV for 2 days. How do I connect?
22 Sep 2024 04:24 PM
I done the recovery process, and now I'm stuck on link your account but can't get on the web page and getting an error message to say there is a technical fault
Hello community. The problem I'm having is the sky stream box flashes white, which this information was on YouTube solve problem issues page. The tv will show SKY logo then a circle will go round and round then it will show on tv. ( Sky HDMI 1 Check Device Power ) it also shows below ( Check that the device is connected properly, then try turning on the device by selecting the button below. ( POWER ON )
That sky message stays on the tv screen. I notice the Sky Box Button not flashing white but gone off, then I notice the sky box was flashing red then the tv screen was updating something. After that the tv was black screen showing ( SKY ) at this stage the sky box is not showing the white flash button, I tried to reset the sky box by pressing the button underneath for 5 to 10 seconds then the sky box will flash white again then go off. I Checked the HDMI 1 port and the power cable and the HDMI 1 cable on the sky box. After doing all that, the ( Sky message comes up Ski HDMI 1 Check Device Power in a white box it says ( POWER ON ) I do apologize for the " Long Message" !! Thank-you
22 Sep 2024 04:26 PM
Follow the advice on the my sky app and you will get your tv working
22 Sep 2024 04:28 PM
You need to follow the recovery advice in post 2 of this thread and as documented here: https://www.sky.com/help/articles/sky-glass-stream-wont-turn-on?area=sky-glass&DCMP=ivr-skycom:ec_gl...
MikeAlanR
22 Sep 2024 04:30 PM
You need to follow the recovery process: https://www.sky.com/help/articles/sky-glass-stream-wont-turn-on?area=sky-glass&DCMP=ivr-skycom:ec_gl...
Hold the button on the bottom of the puck until it starts flashing different colours (green, red, white etc)
MikeAlanR
22 Sep 2024 04:33 PM
@Maxine358150 wrote:Hello community. The problem I'm having is the sky stream box flashes white, which this information was on YouTube solve problem issues page. The tv will show SKY logo then a circle will go round and round then it will show on tv. ( Sky HDMI 1 Check Device Power ) it also shows below ( Check that the device is connected properly, then try turning on the device by selecting the button below. ( POWER ON )
When doing the reset, keep the button pressed for longer, at least 20 seconds or even longer, until you see the lights start to change through different colours, like red, green etc
Follow the procedure exactly as described in post 2 of this thread in the link below, flagged as the Answer post from Sky.
https://helpforum.sky.com/t5/Sky-Glass-Live/Sky-Glass-Power-up-Issues-19-9-24/m-p/4757859#M147519
You do this in the my sky app product settings, open that and go to the manage devices that's where you put your activation code and it links to your account
22 Sep 2024 04:35 PM
Seems the problem is fixed as "there is a problem" is no longer showing and everything is on green and good to go according to sky.
Thanks Peter...didn't work
22 Sep 2024 04:37 PM
Not working....still
This is soo g the same thing to me 😞 giving error message 😭
22 Sep 2024 04:38 PM
You're now connected...set up remote and then activation code and not able to input ...fabulous!
22 Sep 2024 04:46 PM
@lettice left it unplugged longer, still bringing me back to the pin page
22 Sep 2024 04:47 PM
I have tried this and still no joy u fortunately
