3168
Discussion topic: Sky Glass Power up Issues 19-9-24
This message was authored by lettice This message was authored by: lettice
Re: Sky Glass Power up Issues 19-9-24
@BobW2 wrote:
Have been following the sky  instructions exactky for  over 24 hours  Puck does not reset and turn on no matter how many time I  disconnect power, reconnect and hold the rest button till the white then coloured lights start  flashing.  Afer 15+ minutes Puck will not  turn on. What is the problem?
This is the resolution that works, that you have to do.
Follow the procedure exactly that mentions Sky Stream as described in post 2 of this thread, flagged as the Answer post from Sky.
https://helpforum.sky.com/t5/Sky-Glass-Live/Sky-Glass-Power-up-Issues-19-9-24/m-p/4757859#M147519
Sky Community Superuser
Sky Stream (2 pucks), Sky Ultrafast + using Sky SR203 hub. Sky Protect kit tester.
This message was authored by B_har This message was authored by: B_har
I can’t activate my sky glass services through the sky.com/activate link
My sky glass tv is showing a message telling me to link my account through the sky.com/activate this is not working?
This message was authored by Patchnet This message was authored by: Patchnet
Stream/Puck not working - PIN reset also not working
So if I am right this is the section of the SKY website where Sky get its paying customers to do their dirty work and sort out their own issues?  Wow!!  What a business model!!!
My stream/puck stopped working (the phone number confirms they are dealing with the issue but no timeline offered). They tell me to go to the website to "reset" the puck.  I do that and the it get's caught up on the PIN reset which I have to do again and again. So the website sends me to the phone number and the phone sends me back to the website (and also hangs up on me)!! It offers no real help (unless you want to enquire about your bill!!) and so I am stuck with no TV and no idea who to speak to, to resolve this.  Anyone have any suggestions?  Would relly appreciate it?
@Brian300 wrote:
How long it going to be when it back on
It will not come back on unless you do this.
Follow the procedure exactly as described in post 2 of this thread, flagged as the Answer post from Sky.
This message was authored by Rty This message was authored by: Rty
Thank you that guy is beyond annoying
@Bodston wrote:
@Zoltron
I've got to the bluescreen and the puck has downloaded the software update several times. It seems to freeze after that point.
Try this,
Turn off your Sky Stream puck at the mains
Whilst it is off, reboot your broadband router.
Also if you have an ethernet cable attached to your Sky Stream puck unplug it and plug it back in again.
Once your broadband router is back on and working.
Follow this procedure exactly as described in post 2 of this thread, flagged as the Answer post from Sky.
This message was authored by 2320-Jovels This message was authored by: 2320-Jovels
Re: Sky go 403
My Tv is not working I switched it on and off it flash Sky tnen dies
This message was authored by Anonymous This message was authored by: Anonymous
Where is your evidence that it is working in the majority of cases?  According to Sky, it is not working for somewhere between 7k and 10k customers, which is not a small number.  In fact, if those are Irish customers, I would not be surprised if that was a majority of Sky Glass customers in Ireland
This message was authored by Dean1288 This message was authored by: Dean1288
Re: Service down still
Same problem very annoying and Sky Customer Services not answering been on hold for an hour now
This message was authored by Stacy8 This message was authored by: Stacy8
It will not accept my 4 digit pin. I have reset my pin and it still is coming up as incorrect. This is now 24 hours of waiting. I'm currently on hold to sky. I have 2 pucks in the house. One is fine. The other will only make it to this page.
This message was authored by DonHope This message was authored by: DonHope
Hi. We were down for 24 hours. Got it back Friday afternoon. Not sure if some people might not realize when you switch plug off, hold down standby button on side as you switch back on you have to wait 10 or more seconds for the red standby light (that's already on n flashing slowly) to start flashing really quickly. Only release the standby button when flashing quickly.
Goes through update then had to enter all set up details again. Had to change password n pin as elderly parents forgotten it all. Instructions on tv and sky website to change pin if won't accept it. Just need last 4 numbers of account no. paid with.
Hope some help to someone.
This message was authored by Nix37 This message was authored by: Nix37
Sadly not, still getting the oops there has been a problem notification.
Re: Stream/Puck not working - PIN reset also not working
I have exactly the same problem. Round and round and I know people are trying to help but following the instructions hasn't helped me either and gets stuck on the pin page. I'm currently on hold (30 minutes and counting) I will post update once I have spoken to them
This message was authored by Jporch316 This message was authored by: Jporch316
Umm ...... all my devices were off .... all 5 were restored with the recovery process. There will be issues for a few like you who have multiple sky accounts. That, as you say, has been an issue ongoing in different forms for a long time. The majority of users posting in this thread haven't tried the recovery process which you can easily tell by reading the posts.
43inch and 55 inch Sky Glass & 3 Pucks on virgin media M350 hub 5x. 4 x sky mobile sims. Pretend guitar aficionado .. rock on!
When you get to the pin screen pull the plug on the puck for a minute then plug back in and it should continue without the pin
